October 19, 2026, 07:50:03 AM
263 Guests, 0 Users
  • Online today: 1,033
Guests: 263
Total: 263
Real Switch Amps
Started by Atomic_Sheep, February 12, 2018, 04:07:30 PM
Atomic_Sheep
Just wondering, will real aircraft switches work in a low volt, low amp setting of a flight simulator?
Atomic_Sheep
Thanks Bob, a switch is a switch I guess :).
Quote from: Atomic_Sheep on February 12, 2018, 06:04:27 PM
Almost.
Higher current/voltage switches will use the arc when the switch is changed to keep the contacts clean. Over time using a high power switch in a low power application will develop oxidised contacts.
That said, you should be fine in this case.
Atomic_Sheep
Hmm, thinking now. Don't think I have many options though.
Quote from: Atomic_Sheep on February 15, 2018, 12:15:24 AM
For what you are using them for it is a non issue.. Use them....
Aero switches can handle zillions of cycles, which is far from true with regular  toggles or pushbuttons.
Also the feel is 100% different.
Some good stuff also on the market like Carling, Honeywell etc
Pricey though.
As the others have said, don't worry you'll be fine. My comment was aimed at your "switch is a switch" remark.
You wouldnt want to use a household wall switch in a low power application.
Atomic_Sheep
