October 12, 2026, 11:43:37 PM
383 Guests, 0 Users
  • Online today: 1,042
Guests: 383
Total: 383
FSUIPC
Started by N606DL, February 18, 2018, 01:03:11 PM
N606DL
Hello if anyone could help me with this.  I am now trying to set my ailerons. ALL axis's are deleted in P3d. I have no problem calibrating the ailerons except on the same page when I move them, the Throttle axis moves!!! I allready have my Throttles 1 and 2 set and calibrated and working fine. So now When I start a flight my throttles go full when I move my yoke!. Any help would be great.
How are you getting data to FSUIPC, through a Leo Bodner card or equivalent.
I would suspect a bad analog input card. This assumes as you said all inputs in P3D are off, including turning off controls completely.
bravolima
in the FSUIPC/Simflight-Forum you'll find report about problems with new P3D Version 4.2 . Unfortunately Pete D. is on vacation until Tuesday.......
Bernhard
PREPAR3D v4.5 FDS MIP, CDUs, Clocks, Shell, Liners, Tiller; FLIGHTILLUSION Brake-pressure, jaw-damper CPFlight: Overheads, Pedestal; MCP EFIS, OPENCOCKPIT Pedals; FCS: linked Yokes (modified); Weber-Seats on RAIL, ProSim B737 3.0, Aivalsoft EFB Version 2, Navigraph, FSC, BenQ1080 3 Beamer-Visual
N606DL
I am using a Leo Bodner card. I am also running P3d v3. Its a brand new card that I got friday...
ifeliciano
I have FSUIPC installed, but do not use it to interface my joystick axis'. Have you taken the time to read the documentation? It is found here:
\Lockheed Martin\Prepar3D v3\Modules\FSUIPC Documents\
N606DL
Hello, no I have not read the documentation in P3d for this. I will when I get home. I will aslo check to see if controllers are disabled. I know for sure that all axis assignments are deleted...Thank you all for the input.
Just know that FlightSim has a nasty habit of putting them back when it senses a new controller added.
Delete your FSUIPC ini file and let it generate another one. I have had it in the past where
everything looks good but some data  still remains. :2cw:
N606DL
OK thanks guys for the responses. I'll report back. Thanks again.
N606DL
Hello I disabled controllers and that did the trick. Thanks guys ;D
