October 17, 2026, 01:57:58 AM
486 Guests, 0 Users
  • Online today: 877
Guests: 486
Total: 486
Smallest width of a MIP base
Started by kurt-olsson, February 20, 2018, 10:47:03 PM
Hi
My build have minimalistic target and a challenge of being in a small room.
Therefore i want my front window post to be as close to the wall as possible. Kind of like the jetmax.
Right now i have descided for a 40cm width MIP sidewall.
What do you think of this? What does your measure from the panel to windowpost? Do you think i will get into problems with only 40cm?
Thanks.
So are you saying you will chop the FO's side down a little? Not sure I understand what measurement you are looking for. My cockpit I played with the width but not in the front or MIP area. I made it  a little narrower by making my back wall not as wide as it is supposed to be. Cut about a foot to a foot and a half from the overall width.
Sorry, should have made it more clesr that it is the sidewalls for the MIP structure and not the main panel itself. If i understand you have done that by cutting a foot from yours.
Quote from: kurt-olsson on February 21, 2018, 06:27:57 AM
A foot to a foot and a half in the back. I forget I can run down and measure it..
The very back of the cabin is 95" wide.
Thanks a million, will do thesame here!
Quote from: kurt-olsson on February 21, 2018, 11:46:52 AM
Check the width of the seats you want to use. It does make the cabin a little narrower....
Good choice Bob that's pretty much the size of a sheet of MDF or plywood...  ;)
Quote from: Joe Lavery on February 21, 2018, 12:20:05 PM
My  floor section is actually a little bigger then that. But hey it works well! I had a TON of help with it. Could not have don it without Rays and Don....  ;)
