October 19, 2026, 02:32:23 PM
525 Guests, 0 Users
  • Online today: 1,033
Guests: 525
Total: 525
a must have
Started by bernard S, May 06, 2018, 03:20:12 PM
finally it works
not applicable to 73 this a 74 item .. assume the 73  has this feature ? to aid SA
Is ot real CRT screens? 😊
737NGer
Hi Bernard,
Looks amazing!
Would you mind sharing how you set this up (software P/N, Symbol gen P/N etc...?)
Do you think a 747 DEU would connect to an NG DU? I assume that the manufacturer is the same, and thus the signal formatting is identical?
to be honest i do not if signal signal format remains same for 73  ir even if the symbol generator is external.or internal not sure if yiu can even bypass the fmc ...would thevarinc data be the same  i have no idea  also this is applicable to the 74-8 ..thev74_4  does not have this feature ..much to my regret .. so yi7 have ask yourself if yiu aircraft not designed to accept this ..how are you going read/display the data .. update it and what switching are you going to use   its almost another sim within the sim
Bernard
Bump....
But how exactly did you do that ND display?   What software are you using?
Fred
Very nice display, but seems to be a 800 , is'nt it?
yes an 800    as i sa8d not a feature of 400
