Another AC/DC Panel dimenssion request
Started by ifeliciano, May 12, 2018, 10:47:26 PM
ifeliciano
Can someone assist with the A and B measurements?
I have the FDS pane so I assume it will be spot on!
A is 45.5mm
B is 14mm
Hope that helps.
OEM measurement is 20.5mm x 35.5mm
OEM panels use the short switch guard for this switch, where FDS use the standard one
ifeliciano
Thank you gents!! I was pretty darn close in my original design 19.5mm x 33.25.mm.
here is yiur solution re panel sizes get 1.1 cockpit posters used for t3aining aids
