November 03, 2026, 04:50:18 AM
240 Guests, 0 Users
  • Total Topics: 7,914
  • Online today: 395
Guests: 240
Total: 240
ISLOGO
What is Instructor Station™ ?
The Instructor Station™ is meant to assist Aviation Professionals, Flight Simulation Enthusiasts and Home Cockpit Builders using Microsoft® Flight Simulator (FS) 2004™, FSX™ and ESP™, Lockheed Martin Prepar3D® and X-Plane®.
The Instructor Station™ allows setting the aircraft on an approach to a runway of choice under any weather conditions, start-up and shutdown network computers (fully customizable), program or set aircraft system failures at any moment, calculate the amount of fuel required for a flight and load it to the aircraft, record flight performance (approaches, manoeuvres, landings, take-offs, etc.) and plot it graphically, and many other things!
AYUDAAAA!!!!! CON WIDECLIENT
Started by a320kH, August 19, 2018, 12:04:37 PM
a320kH
Hola Chicos, soy nuevo y este es mi segundo post, les cuento que estoy fabricando una cabina A320 en base a Jeehell A320 FMGS, y el espectacular IStation de Luis Gordo, el tema es que en el PC donde tengo FSX cuando esta cargado y listo dice: WideServer: waiting for clients  y en el NOTE tengo WIDECLIENT, cuando activo el WideClient me dice connect, pero a los pocos segundos tanto el pc de FSX como el Widclient dice : waiting for clients   connect, waiting for clients   connect y el IStation no me conecta al PC de mas menos FSX.  Ya revise las conexiones de red los FIREWALL y estan desactivados, tambien lo conecte via RJ45 y nada..... ma pueden ayudar si alguien sabe mas menos del tema por favorrrrrrr  :huh: :'(
I do not understand Spanish...but try this....
Make sure that you have the Server IP address entered in the WideClient ini file.
If that line is not there,  simply enter the line per the instruction manual.
luisgordo
Alex,
I believe we solved this via email.  If not, please advise.
Luis
Instructor Station
www.iStationGordo.com
Flight Data Recorder Mobile
a320kH
Hola Luis, te envie el correo el cual hablamos, pero aun no me respondes, si lo puedes  revisar por favor gracias
a320kH
Quote from: a320kH on August 30, 2018, 04:09:48 PM
luisgordo
Alex,
I believe this is solved.  If not, please advise.
Luis
Instructor Station
