October 14, 2025, 05:44:16 PM
547 Guests, 0 Users
  • Total Topics: 7,886
  • Online today: 703
  • Online ever: 1,343
Guests: 547
Total: 547
MCP Frame (what material should i use)
Started by kurt-olsson, August 19, 2018, 09:35:37 PM
Hi
I have attached my MCP and EFIS structure to a wood beam, it works but it wiggles abit and you cant put your arms on it and let all your weight down i am afraid it will snap.
What i need is a thin metal plate that dont flex and that i still can drill wholes in that the mcp can be placed on to.
Kind of like the real MIP structures.
What material is the strongest/lightest/less flex that i still can drill in.
It needs to be about 60x60 cm
This is how I did it on my previous sim.
Was rock solid
Maybe you can adapt that to your structure ?
Looks good and i can implement this on my structure. What material is it and where did you get the long metal plates?
Aluminum T or L section and a few bolts... ::)
Worked really great, now i easilycan add a 20kg 737 manual ontop my mcp! :)
I took two long wood beams and attatched my mcp frame to it. I had to cut the metal structure to mcp to attach the wood but it turned out to be great.
Looks real nice Nick!
I will do the same and also reinforce the glarewings.
Hope my support structure wont be visible from the seat while flying.
Atomic_Sheep
I've come to the realisation that I'm not as smart as the people designing these things, so copying them is the best course of action if you can get your hands on how the originals were made. The other problem of course then becomes working with materials that most people are not familiar with. Woodworking is obviously much more common than metalworking and I'm sure the originals were made with metals, so that's a bit of a problem when trying to copy. I guess the least you can do is to copy the design but in wood with thicker bits.
True that, thats what i did. Worked really great.
