October 16, 2026, 09:34:17 PM
583 Guests, 0 Users
  • Online today: 849
Guests: 583
Total: 583
Your Aircraft Drawings & Dimensions...Google Searching
Started by blueskydriver, September 07, 2018, 10:49:47 PM
Hey Everyone,
Likely some folks know this, but I was searching for some Drawings & Dimensions on B737 items and realized a simpler way to find all sorts of things.
For example, are you making all your own stuff like the MIP, Overhead, Seats, Rear Bulkhead and so on, or just looking for something like the yoke to floor height and angle.
Well, if you search Google (I use Apple Safari) and use B737 Drawings & Dimensions, then select images and show all, you will get results from any web page that has any drawings and dimensions for the B737. No matter whose site it comes from, it'll just be the images that are shown. Now, if you add PDF behind the search terms B737 Drawings & Dimensions PDF, you will get the same, but in PDF.
If you have a different type of aircraft just change that portion in the search...example A320 Drawings & Dimensions. You will get everything for that plane. Mind you, in all search cases the first images shown are usually the full aircraft body with fuselage, wings and etc measurements. You need to scroll down through that and maybe even pages, but you will start seeing items of drawings from just about any website that has them, and I even mean things that some builders have just hand drawn.
Why do this? Well, there are many times people post on the CB looking for measurements, and they may be on here or they may not, but by using Google as I described above you will most likely find what you're looking for, as well as many other drawings & dimensions. Of course, do try the Cockpit Builders search box first, as you'll likely also get the postings/conversations about what you're looking for...
Happy Searching,
