October 19, 2026, 06:01:55 PM
366 Guests, 0 Users
  • Online today: 1,093
Guests: 366
Total: 366
Just to make sure i am not doing anything stupid
Started by kurt-olsson, September 21, 2018, 09:47:33 AM
I am 99% of this answer but i want to check anyway.
When dealing with both 5v and 24v in a circuit i join the negative black cables from each power supply in the circult.
example is a circuitboard i am creating that uses a mosfet fed with 5v for backlight. And also i use 24v for the ULN2803A darlington driver. On the circuitboard i connect both negative together from each PSU and also to my teensy GRND.
My question is that i would like to join the negative on a separate bus so i only got three cables coming in to each panel.
5v+, 24v+ and negative black.
Otherwise i have two negative cables, not that much hazzle but its more simple to just have one.
What do you think?
Not finished but this is the circuitboard i am working on. It will add a 5v mosfet for dimming backlight.
Then all negative cables are joined together.
By the way Rob, if your still selling your curcuitboards i am very interested =)
