Toggle Switch Boeing Solenoid
Started by jackpilot, May 11, 2010, 06:28:31 AM
I got this new solenoid switch on EBay  for $9.99.
Not sure what it is, APU start?
Any idea?
Not sure jack..  Looks neat though, and if you got it for 10 bucks, thats a great deal.
There are a number of switches that are supposed to work that way in the overhead.... But would work great for APU if it is 3 position...
Seems that would make a nice APU start switch.. Also keep in mind that you would not have to use the solenoid part if you used it for a 737 APU..
i have one of those just like that that I got from Nick at APHS.   He said it was for the APU start.    I was going to use it but it wont on my overhead in that spot due to spacing with other switches so i will ebay it.
Based on what you paid I would say you found a great buy.
dnoize
It probably comes from a 747 (100/200: aux power panel - not locking in the center position) or 727 (engine bleed panel - pull to unlock the center position).
If so the solenoid will hold in both ends and only the center position is locked (with the 727 switch).
Although most 737 apu switches dont have solenoids, it IS an option. In those cases the solenoid only holds the APU start position and the OFF and ON positions are fixed (without solenoid), both positions locking - pull to unlock.  (as far as i know).
If you want to use it as a 737 APU start switch you need to find a way to lock the OFF position also since it spring returns to center (ON) when the solenoid is powered.
If its one of the above switches, both positions are powered by the same terminals, so not 2 independent solenoids.
Either case, at 10$ its a bargain anyway !
Stef
Efe
This is what Nick has on his site as the 737 APU start switch.
__________________
Efe
dnoize
dnoize
it can easily be modfied though.....on top of the switch you can see a small metal blade. This has a hole in the middle (where the lever locks in the center position.)
You can easily drill a hole in the top (off position) as well so it locks there too without using the solenoid.
then you have to pull the lever to get it out of the OFF position and out of the ON position and you can use the solenoid for the START position.
But like i said earlier: 9 out of 10 737's DONT have a solenoid APU start switch.
