October 16, 2026, 10:58:05 AM
456 Guests, 0 Users
  • Online today: 849
Guests: 456
Total: 456
Flight deck solutions FDS-B737NG-PRO-MX- rudder pedal
Started by Mach7, July 10, 2019, 04:58:57 AM
Mach7
Just thought I would drop a note of warning for anyone that has these type of pedals installed.
I emailed Peter Cos. (FDS), with respect to servicing the forward push pull rod bearings as they have grease fittings that would lend one to believe they could be utilised with a gun for lubrication purposes.
The tech department suggested an annual grease application with a grease gun.
After purchasing the smallest gun I could find, I successfully greased my first bearing but when the gun was removed it took the entire fitting with it.
In actuality these are cheap push on adaptors that do not even contain a retention spring ball, and are more like dust covers than anything else.
The solution to this problem was to purchase a spray can of lithium grease, and service the remaining bearings that way.
The spray can idea works perfectly fine!
I have since contacted FDS and they have been very supportive and advised they may put out a warning with respect to these fittings.
757Simulator
ifeliciano
Mach7
Yep....the needle adaptor was my second trip to Canadian Tire, prior to (returning the grease gun) to get a refund. In actuality it is "pointy", but not "needle" enough to fit in the hole.
