World of AI question
Started by jackpilot, May 21, 2010, 03:24:16 PM
I had  world of AI aircrafts installed, very pleased with it , now I cant see any one of these airplanes, airports are only populated with scarce FS traffic....just looks like WAI is not active anymore.
Any idea from users ? (besides a reinstall).
JAck
EAL727Capt
Bonjour, Jack.
Did you adjust the traffic level?  In FS9, OPTIONS->SETTINGS->TRAFFIC/
I'm not sure where it is in FSX but am guessing its something similar.
When I first loaded WoAI, it took my settings down to below 10%.
Just a thought.......
Jay
Keep the pointy end up and forward.........
I tried all kinds of setting for that ...to no avail.
andarlite
2 things you should check:
1) Woai installs the traffic files in your fs2004\Scenery\World\Scenery folder. Check to see if they are there ...filename should look like Traffic_nnn_WoA_airline.BGL
2) Check your Aircraft folder for the Woai aircrafts. The filenames all start with WoA_
If you can't find them there then you probably need to do a re-install.
Henry
Level D 767
FSX
Files are in the right place !!!
