12"monitor
Started by jackpilot, June 09, 2010, 11:40:21 AM
Got this one on Ebay 1024X768 , 12" diag. 4X5 for $100
The red square is the inside size of a DU Bezel.
Will use it for the lower DU (Quickmap /Check list). The unused right part will be under the dummy FO CDU.
It is also  a good size  for a side EFB,  It covers the whole bezel ,as opposed to  10 inchers, (much more expensive) which are not high enough to fill it.
I'm using a 12" for my engine stack guages. $100 ain't bad!
