2 fmc units from poldragonet
Started by Solarhawk07, May 21, 2020, 12:56:05 PM
Solarhawk07
Hi All
i have just bought these units and was wondering how i work them with xplane 11?
could someone explain to me how i wire this up it seems to have everything there
i have managed to get the back lights working
but now im flumoxed
cheers
heres a few pics
Hello,
Thanks for posting.
The USB connection basically treats this unit like a keyboard.  connect the usb, and windows should recognise this as a keyboard.
for the zeibo, you likely will have to click on the fmc with your mouse in the aircraft to be able to start typing on the fmc keyboard.
Next to the yellow power adapter wich will likely by a 5V power supply input you will need to conect you will see that red RCA connector, this is what I was talking to you about last night on stream, you will need a composite ouptut device from your computer.  some thing like this.
https://www.amazon.com/Converter-Adapter-Composite-Supports-Laptop/dp/B0821723M3/ref=sr_1_27_sspa?dchild=1&keywords=pc+composite+monitor+output+usb&qid=1590097088&sr=8-27-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyNjJYWTNJQTBNNzg3JmVuY3J5cHRlZElkPUEwNDc3NDE5MkhWTVYxSTNUMzVZUyZlbmNyeXB0ZWRBZElkPUEwNDgwMDE2TEpFWjQ4WVI4NU1GJndpZGdldE5hbWU9c3BfbXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
this converts HDMI to composite output (the yellow cable)
Before you spend money though connect a 5 volts + tip power adapter to the input and ensure the LCD backlights light up. These are old Sony PSOne Screens.  So get a psone power adapter like this.
https://www.amazon.com/Wiresmith-Power-Adapter-Sony-PSOne-PlayStation/dp/B07SQDVZPC/ref=sr_1_1?dchild=1&keywords=sony+psone+power+adapter&qid=1590097179&sr=8-1
Looks like someone had Buggered the monitor wiring see posts like this, to fix the wiring.
http://www.737ng.co.uk/djb/opencockpits_fmc.pdf
or
http://blog.retroleum.co.uk/electronics-articles/psone-lcd-info/
make sure the monitors work or go with something like this..
https://www.adafruit.com/category/338
Solarhawk07
ah cheers man i appreciate that big time
ill get right on it
much respect to you
