OEM Audio Control Panels for B737's - wiring and integration question
Started by kattz, December 27, 2020, 02:08:14 PM
kattz
Has anyone here had any luck in integrating the OEM audio control panels?
I have two Avtech units.  I also have an older Gables B737CL unit with two cannon plugs, but the two NG(?) units only have one cannon plug on the rear, p/n 5145-1-75 and 5145-1-61.
I'm thinking that they are ARINC429 devices.  Anyone have a pinout or a wiring diagram?
Thanks.
Kev
Did you try Avtech first. Nothing to loose.
(Gables supplied me with pinouts on a few OEMs)
kattz
I registered on their site today earlier, but no manuals available.  I left a message with their repair shop.  Everyone is probably out for the holidays.
kattz
Well...
I have the CMM's for the panels.  And for the system controller as well.
However, the sad part is that to synthesize all of the signals coming in and going out of the controller is unrealistic to say the least.  And not ARINC429.  Proprietary bus.
The simplified explanation is that the audio control panels (newer, single C/P interface, 5145-1-XX p/n's) as well as all mics, masks, PA amp, and all nav radio signals come into the system controller.  And looking at the system controller, these signals are not just an audio signal.  All have particular reference kHz, ohms, etc.
Some diagrams attached for reference.
I was really hoping for ARINC429 or an easy discrete solution.
So, the next step is to decide, use these OEM panels that I have and break everything out to analog and I/O cards (that will take some serious time!), or buy a unit built for a simulator?
I know that there is a sim component maker that is releasing an almost-fully functional ACP in the near future.  However, I was told this in confidence and you'll have to wait for their press release for that one.
