October 13, 2026, 11:11:05 PM
426 Guests, 1 User
Guests: 426
Total: 427
Request Airbus FCU and EFIS Dimensions
Started by asenyurt, January 19, 2021, 12:22:51 PM
asenyurt
Hi guys
I am making Airbus FCU and EFIS hardware and i need square, rectangle, round buttons dimensions.
Thanks for your helps
Hi Atakan,
If you don't have any luck getting these dimensions, you can get pretty close by scaling the sizes from an image like the one attached.
All you need is one known size, like the panel itself perhaps. Then apply that scale in a photo editor and measure the buttons ect from the image. you can zoom in to take the measurements, to make it as accurate as possible.
Of course the higher the resolution of the image, the closer you will get.
Then take the same approach to the depth as well. Hope that helps.
for panel sizes get duz rail and count the  connectors on panel to match   there isca formula but i dont know it sorry
Bernard, looking at it I don't think that panel is mounted on a Dzus rail.
This is the specs for Dzus:
asenyurt
Hi Joe,
Scaling images helped me.
Here is last result. I think it looks like original ha ?
There ya go, ame found exactly what you needed!
brianwilliamson
When I started in 1999 that was the only measurements I could find and the photos that are posted there are the ones I used !!
Lots of work but can be done.
.......Brian W.
plus 3 control computers.
