738NG trim wheels speeds question
Started by Wendy, November 20, 2026, 01:35:06 AM
Wendy
Hello All,
It's been quite some time since I posted something here..
I have a question about the speed of the trim wheels.
In Prosim there are 4 gate's to activate the different speed settings to rotate the trim wheels.
They are:
-AP high speed
-AP low speed
-Manual high speed
-Manual low speed
I can activate these gates to the extra microcontroller I have placed in the throttle and couple them to different speed settings for the trim wheels in my setup. I included 4 potentiometers to adjust the 4 settings. These potentiometers control the PWM I sent to the Pololu VNH5019 driver. The system works but I have no idea how fast/slow the wheels need to turn.
I can only find some speed references as 0.09 units/sec and 0.2 units/sec ???
Is there somewhere or someone that has more info on how fast the wheels turn or how long it takes for example to move the trim indicator 1 position.
Any help would be greatly appreciated,
Wendy
Panel builds, ProSim, Sismo boards, MSFS2024
https://flightsimpartseu.odoo.com/
https://www.flightsimparts.eu/ (not updated anymore)
Hi Wendy,
I have done some digging.  I know they can spin fast enough to bite you if you aren't careful.
I couldn't find an exact figure in any of the Boeing manuals I have access to. The Boeing 737NG Flight Crew Operations Manual (FCOM) and Aircraft Maintenance Manual (AMM) only give how fast the stabilizer trim moves, not how fast the wheel spins. You can work it out from two published figures, though.
1. Autopilot trim rate on the 737NG
  • Flaps up: 0.09 units per second
  • Flaps down: 0.27 units per second
  • For comparison, the thumb-switch trim runs at 0.2 units per second flaps up and 0.4 flaps down.
2. Wheel gearing: I have been told by pilots and maintenance people that the wheel turns about 15 times per unit of trim on the NG. The older 737 Classic is about 10.
What that works out to on the NG:
ModeTrim rateWheel speed
Autopilot, flaps up0.09 units/sabout 1.35 turns per second (about 80 RPM)
Autopilot, flaps down0.27 units/sabout 4 turns per second (about 240 RPM)
Thumb switch, flaps up0.2 units/sabout 3 turns per second (180 RPM)
Thumb switch, flaps down0.4 units/sabout 6 turns per second (360 RPM)
I hope that helps. Trev
Wendy
Hello Trevor,
Thanks for the info, it looks like I can transform this info in some sim motion.
I think I'l have to bold the TQ very well otherwise he take will take of on his own  :laugh:
Regards, Wendy
Quote from: Wendy on November 20, 2026, 07:43:47 AMHello Trevor,
Regards, Wendy
That's what I am afraid of, especially when these "simulated  TQ's" aren't really built to take that kind of movement.  On the Sim we fly for worldflight, we use the throttle stab trim cutoff switches to shut the motors off, its just too risky and might make me spill my beer.
Wendy
You don't want to spill any beer, you better drink it   :P
