July 03, 2026, 01:05:31 AM
2644 Guests, 0 Users
  • Total Topics: 7,902
  • Online today: 2,475
Guests: 2644
Total: 2644
FSX - no taxi lights
Started by firstinflight, June 20, 2012, 09:39:28 PM
firstinflight
Nick's thread on this was old and not responded to in over a month...Hence starting a new one.
I have the same issue.
Landing lights. - yes
Taxi lights - No
Stock 737.
CPJ
www.simulationresearch.net
FSX, Jetstream 737, Prosim737, Engravity CDUs, CPFlight, Active Sky 2012, Ground Environment, AI Traffic, UT Europe, PilotEdge, NThusim, Aerosoft Airports, Dreamteam airports
I dont think FSX supports Taxi lights
Quote from: XOrionFE on June 21, 2012, 09:07:00 AM
..or maybe the other way around. When I taxi, the lights turn when I turn the tiller and I don't think the landing lights would do that. So they may be one & the same since I do not see any difference when taxiing when I turn both of them on.
Quote from: maurice on June 21, 2012, 10:10:07 AM
I think there is a add on you have to use to get the landing lights on the stock 737 in FSX. Been a while so I am not sure.
Mink
With the 3d redux light vom shockwave you get taxilights on the default 737.
Take a look in their forum. A2A forums.
Greetings from Germany.
Kresimir
Quote from: Mink on June 21, 2012, 10:24:35 AM
Kresimir
I did install that a while back and I still did not see any difference on the ground if both lights are turned on. But it could well be I did not program my overhead lights correctly.
Mink
In the normal installation from the shockwave lights, you will not see them. You have to make manually changes in the aircraft config file. Which can also be found in the forum.
Kresimir
Quote from: Mink on June 21, 2012, 10:33:22 AM
Kresimir
I guess I should have read the manual  :)
Hey Maurice,
Heading to doctor's now, but can show you the aircraft.cfg changes later. Actually, if you search CB you should find postings I did about that for the FSX default 737, and both the PMDG 737NG and 737NGX versions...
BSD
firstinflight
Thanks folks! I will implement the advice today.
Wonder how many PhD dissertations would be generated if one could cumulate all the insight on these forums about this hobby... :-)
i feel grateful for the wonderful community we belong to...
Here are the aircraft.cfg's for the FSX default 737-800:
[LIGHTS]
//Types: 1=beacon, 2=strobe, 3=navigation, 4=cockpit, 5=landing
light.0 = 3, -25.00, -58.20,  3.90, fx_shockwave_navred ,
light.1 = 3, -25.00,  58.20,  3.90, fx_shockwave_navgre ,
light.2 = 2, -71.52,   0.00,  5.92, fx_shockwave_strobe_l_nl ,
light.3 = 2, -25.20, -58.20,  4.20, fx_shockwave_strobe_l_2 ,
light.4 = 2, -25.20,  58.20,  4.20, fx_shockwave_strobe_l_3 ,
light.5 = 2,  -7.55,   0.00, -5.50, fx_shockwave_beaconb ,
light.6 = 1,   2.00,   0.00,  8.70, fx_shockwave_beaconh ,
light.7 = 4,  47.60,   0.00,  3.00, fx_shockwave_vclight_l ,
light.8 = 3, -29.50, -56.60,  3.70, fx_shockwave_navwhi_l_nl ,
light.9 = 3, -29.50,  56.60,  3.70, fx_shockwave_navwhi_l_nl ,
light.10 = 5, 5.6, 7.28, -1.47,  fx_Shockwave_landing_light_narrow      // Shockwave light
light.11 = 5, 5.6, -7.28, -1.47,  fx_Shockwave_landing_light_narrow   // Shockwave light
light.12 = 5, 41.85, 0.0, -6.8,  fx_Shockwave_landing_light      // Shockwave light
light.13 = 5,  36, 0, -18, fx_shockwave_landing_light_light,
Just copy and paste it as is, the line corrections will be done in the aircraft.cfg.
Here is the PMDG 737-700NG:
[LIGHTS]
Types: 1=beacon, 2=strobe, 3=navigation, 4=cockpit, 5=landing 6=taxi
light.0 = 2, -106.828, 0.090, 5.989, fx_shockwave_strobe_l_3 , //Aft Strobe
light.1 = 1, -42.352, 0.000, 8.584, fx_shockwave_beaconh , //Top Beacon
light.2 = 1, -50.473, 0.000, -5.873, fx_shockwave_beaconb , //Bottom Beacon
light.3 = 3, -66.685, -56.370, 1.940, fx_shockwave_navred , //Left Nav Light red
light.4 = 2, -66.202, -55.586, 1.940, fx_shockwave_strobe_l_2 , //Left Strobe
light.5 = 3, -66.685, 56.370, 1.940, fx_shockwave_navgre , //Right Nav Light green
light.6 = 2, -66.202, 55.553, 1.940, fx_shockwave_strobe_l_2 , //Right Strobe
light.7 = 3, -72.350, 56.550, 1.500, fx_navwhi_pmdg , //Right Wing Aft Position Light
light.8 = 3, -72.350, -56.550, 1.500, fx_navwhi_pmdg , //Left Wing Aft Position Light
light.9 = 3, -106.828, -0.090, 5.989, fx_navwhi_pmdg , //Aft Position Light
light.10 = 5, -38.500, 6.750, -2.000, fx_Shockwave_landing_light_narrow,//Right Inboard Landing Light
light.11 = 5, -38.500, -6.750, -2.000, fx_Shockwave_landing_light_narrow,//Left Inboard Landing Light
light.12 = 5, -39.500, -2.500, -6.000, fx_Shockwave_landing_light_narrow,//Bottom Left Landing Light
light.13 = 5, -39.500, 2.500, -6.000, fx_Shockwave_landing_light_narrow,//Bottom Right Landing Light
light.14 = 8, -54.000, -40.000, 0.000, fx_pmdgwinglight,//winglight illumination
light.15 = 8, -54.000, 40.000, 0.000, fx_pmdgwinglight,//winglight illumination
light.16 = 5, -33.500, -11.750, -2.000, fx_pmdgland, // Engine Illunination Left
light.17 = 5, -33.500, 11.750, -2.000, fx_pmdgland, // Engine Illumination Right
light.18 = 6, -12.000, 0.000, -7.750, fx_shockwave_landing_light_small_xenon,// Taxi Light Nose Gear
PMDG737-800NG:
[LIGHTS]
light.0 = 2, -130.000, 0.090, 5.989, fx_strobe_pmdg, //Aft Strobe
light.2 = 1, -51.750, 0.000, 8.700, fx_beaconh_pmdg, //Top Beacon Blink
light.3 = 1, -65.900, 0.000, -5.600, fx_beaconh_pmdg, //Bottom Beacon Blink
light.4 = 3, -79.000, -55.665, 2.100, fx_navred_pmdg, //Left Nav Light red
light.5 = 2, -80.000, -55.986, 2.100, fx_strobe_pmdg, //Left Strobe
light.6 = 3, -79.000, 55.665, 2.100, fx_navgre_pmdg, //Right Nav Light green
light.7 = 2, -80.000, 56.200, 2.100, fx_strobe_pmdg, //Right Strobe
light.8 = 3, -84.800, -56.737, 1.800, fx_navwhi_pmdg, //Left Position Light
light.9 = 3, -84.800, 56.691, 1.800, fx_navwhi_pmdg, //Right Position Light
light.10 = 3,-130.000, -0.090, 5.989, fx_navwhi_pmdg, //Aft Position Light
light.11 = 5, -51.60, -6.50, -1.70, fx_shockwave_landing_light_narrow.fx // Shockwave light
light.12 = 5, -51.60, 6.50, -1.70, fx_shockwave_landing_light_narrow.fx // Shockwave light
light.13 = 6, -14.00, 0.00, -4.50, fx_Shockwave_landing_light_small.FX // Shockwave light
light.14 = 5, -52.30, -2.50, -5.30, fx_shockwave_landing_light_narrow_down // Shockwave light
light.15 = 5, -52.30, 2.50, -5.30, fx_shockwave_landing_light_narrow_down // Shockwave light
light.16 = 5, -12.80, 0.00, -7.6, fx_shockwave_landing_light_narrow // shockwave light
light.17 = 8, -51.60, -6.50, -1.70, fx_shockwave_landing_light_narrow_down.fx // Shockwave light
light.18 = 8, -51.60, 6.50, -1.70, fx_shockwave_landing_light_narrow_down.fx // Shockwave light
PMDG737-700NGX:
[LIGHTS]
//Types: 1=beacon, 2=strobe, 3=navigation, 4=cockpit, 5=landing, 6=taxi, 7=recognition, 8=wing, 9=logo, 10=cabin
light.0 = 2, -53.828, 0.090, 7.989, fx_shockwave_strobe_3, //Aft Strobe
light.1 = 1, 10.300, 0.000, 10.800, fx_shockwave_beaconh, //Top Beacon
light.2 = 1, 2.500, 0.45, -3.50, fx_shockwave_beaconb, //Bottom Beacon
light.3 = 3, -14.000, -56.370, 4.000, fx_shockwave_navred , //Left Nav Light red
light.4 = 2, -15.202, -56.586, 4.000, fx_shockwave_strobe_2, //Left Strobe
light.5 = 3, -14.000, 56.370, 4.000, fx_shockwave_navgre , //Right Nav Light green
light.6 = 2, -15.202, 55.586, 4.000, fx_shockwave_strobe_2, //Right Strobe
light.7 = 3, -72.350, 56.550, 4.000, fx_navwhi_pmdg , //Right Wing Aft Position Light
light.8 = 3, -72.350, -56.550, 4.000, fx_navwhi_pmdg , //Left Wing Aft Position Light
light.9 = 3, -53.828, -0.090, 5.989, fx_navwhi_pmdg , //Aft Position Light
light.10 = 5, 13.600, 6.8, .400, fx_Shockwave_landing_light_narrow,//Right Inboard Landing Light
light.11 = 5, 13.600, -6.8, .400, fx_Shockwave_landing_light_narrow,//Left Inboard Landing Light
PMDG737-800NGX:
[LIGHTS]
Finally, those are not for the winglet versions, if you need those, they should be on the A2A website.
BSD
Thanks very much John. You always seem to have all the answers I need   :)
Glad to be of help Maurice. If you get the A2A Lights add-on let me know and I can tell you how to get that taxi light working, as well as more about editing the light point positions, if you need to make changes to them...
Mink
#13
this is my fsx default 737-800 shockwave lights setup.
in the panel cfg put this as the last gauge number, mine is 29:
gauge29=shockwave_lights!SW Lights_taxi_gear,  1,1,1,1 //shockwave light
aircraft cfg:
[LIGHTS]
light.12 = 6, 41.85, 0.0, -6.8,  fx_Shockwave_landing_light      // Shockwave light
light.13 = 6,  36, 0, -18, fx_shockwave_landing_light_light,
firstinflight
Just to confirm, the net of this discussion is that you absolutely need shockwave lights... Am i right?
Quote from: firstinflight on June 24, 2012, 05:07:48 AM
Well you either need ShocKWave lights, another light add on or a aircraft that has landing lights built in.
Quote from: blueskydriver on June 22, 2012, 01:02:50 AM
Hi John,
I finally got around to trying to get the taxi light to work but it still does not work for me. On;y the landing lights are working. Not that big a deal since I never get to see the plane from the outside anyway but it still bugs me that they don't work  :). I have the Shockwave lights and the configuration in the aircraft.cfg file is the same as the one you posted earlier but no joy.
Anyway, if you have any ideas, please let me know but if not, that's quite OK as well.
 Do not feel bad Maurice, your lights will not turn on and my FSX will not start, go figure!!!!
Quote from: firstinflight on June 20, 2012, 09:39:28 PM
Taxi lights - No
Stock 737.
CPJ
CP,
  Just use Xplane.. that will solve all your problems!    ;)
Quote from: Sam Llorca on August 15, 2012, 05:13:32 PM
Sorry Mau cant help with this one
Sam - Your still not able to get fsx started even after all these weeks?
Hey Maurice and CPJ,
I will post how to do this later for the both of you...
Sam, same question as Gary? What's the deal? Have the electricians came yet? OMG! I'd be insane by now...uh, wait...I am insane already! Well, I'd be more insane then, if I was in your shoes! Does it have to be a certified electrician to do the work? Heck, the electrical codes tell you how to do everything, you can do it yourself and have it inspected by the county or local inspector. As long as he/she approves and you pay their bribe...oops, I mean fees, you should be good to go.
I hired a new electric company to finish the job, they said that the delay is on the transformer they have to custom build for the platform, according to them it will only take onother 3 weeks, but that is not what I was refering to when I said that "my FSX will not start" literally my FSX program will not start, I give up messing with it and pass it on to FDS, Steve was trying to get it running last night for hours, don't know what happened, it was working at FDS when it left, when it got to my place I tried to start it and keeps popping up a message with "FATAL ERROR, program will shut down", at start up, after a week I was upset, now I got used to it, Steve is going to continue working on it this afternoon. I think I'm ready for X-Plane!!!
mattford1
Sam-
Once you go to xplane you will never look back!  It's absolutely blows FSX out of the water in my opinion.  Not to say there won't be growing pains, but it's really worth it.  I know James and I are so glad we switched.
Best,
Matt
